LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   maf code. don't know whats up. (https://ls1tech.com/forums/general-maintenance-repairs/1063071-maf-code-dont-know-whats-up.html)
dutinsss Feb 10, 2009 03:42 PM
i got my car tuned a few weeks ago and i thought he tuned out all the codes, but my SES light came on when i was on my way home. i got the MAF and the skip shift code. i had a spare maf sensor at the house so i cleaned it and put it on and cleared the codes, but they just came back on again. i'm guessing he just forgot to delete the skip shift code, but what else could be causing the MAF code to be thrown? i believe it was p0102.
2001NBMZ28 Feb 10, 2009 04:20 PM
See if the ENG SEN fuse is blown - the MAF, 02's, skip shift and reverse lockout are all on that circuit. If it's also harder to get the shifter over to reverse that's probably it.
dutinsss Feb 10, 2009 05:01 PM
i bet thats it! it's been hard to get out of reverse for months and i didn't see a fuse for the lockout solenoid so i just figured it was bad. i'll swap the fuse out and see if it fixes it.
MattIROC Feb 10, 2009 06:00 PM
If it keeps blowing, you have a ground issue. Most likely your o2 sensors touching something.
mcamarols1 Feb 12, 2009 02:33 PM
yeah what MATTIroc said, took me 2 weeks to figure it out lol
CamaroFan71 Feb 12, 2009 02:49 PM
Where is this fuse loacted at man?
2001NBMZ28 Feb 12, 2009 04:47 PM
Under the hood, fuse and relay center 2.
MattIROC Feb 12, 2009 05:36 PM
My buddy had the same problem with his 98 TA recently, and after numerous fixes which he had thought fixed it, turns out one of the rear o2's was just sitting on top of his tranny, and it was causing that fuse to short out. He spent a week or two finding the issue, and is damn happy now!
In my old 6spd (which the same buddy I spoke of above ended up buying) after I did headers and exhaust, I had the same problem. My issue was the passenger side front o2 was hitting the header, and it was actually the middle of the harness that touched lightly while I'd be driving.
Hope you fix it! I'll get my buddy to chime in that had the same issue, he might have something else to add.
'98 Black TA Feb 12, 2009 05:41 PM
I had an issue with the drivers side 02 touching. I have hooker LT's on the car and the eng ses fuse would only blow with a hard launch from a dig. I found out the engine would torque just enough for the 02 to touch the frame. When I took the 02 out you could see where the bare wires were. I could not see it while the 02 was in. So if that fuse is blowing you have a wire grounding out somewhere. Good luck.
dutinsss Feb 12, 2009 11:45 PM
i checked the fuse and sure enough, it was blown. after i swapped it out, i cleared the codes and the SES light stayed off and my reverse lockout is fixed! thanks for the help, guys.
dutinsss Feb 12, 2009 11:46 PM
oh yea, before i got corvette o2's, my drivers side extension melted on the header so that must have been what blew it.
mcamarols1 Feb 13, 2009 06:02 AM
good to know yiu fixed it
donalr76 Jul 5, 2009 04:24 PM
My car has been doing the same thing the las couple of days. I am about to check it out right now.
donalr76 Jul 5, 2009 08:26 PM
The resistor that is in my skip shift plug was pressed up against my transmission making it blow out my engine sensor fuse. Zip tied it in a better place and everything went back to normal.
© 2026 MH Sub I, LLC dba Internet Brands
