overheating and stumped!
list of things I've done
radiator cap
purged it 4 or 5 times
waterpump is working
replaced thermostat
Is there a diagram that shows the water line layout to see if all the waterhoses are in the correct spot?
and I have flushed the heater lines and core.
I don't know the history of the car but it runs reallly strong and no water in the oil and no white smoke out the tail pipes.
What should I try next?
thanks Lee
The ONLY thing that keeps your coolant cool while in stop and go city driving is the fans, nothing else. The front lower air dam, yea it helps, but the air dam is mainly for the highway.
I had replaced every peice but that and that solved the problems.
Also when bleeding the system, put the front up on jack stands, so the bleeders are at the highest point and not getting air locked.
Also, the fans on the LS1's 1997+ have two settings high/low. I'm not sure about the LT1's. So make sure they are working on both high and low if they do that too.
You can pull the radiator and try to flush it youself and see if you get any crap out of it.
