bad vibration after t56 swap! help
I have a 98 z28 that i put a complete swap from an m6 swap i even used the flywheel that the swap car came with...only thing now is a bad vibration around 1200+ rpm ..the swap came with new trans mount think it was a poly but my car had 150k miles original mounts plus 4l60e was a pita to get out had kick sob to get it out ...can anybody give me an idea what it might be flywheel,mounts? I have new poly mounts and rubber tranny mount comming just in case thats it ? can anybody help please
If the vibration is engine RPM sensitive look for something ahead of the transmission (clutch, flywheel). Does it vibrate the same whether its sitting, moving, in all gears?
I would suspect a balance/harmonic vibration issue with the flywheel and/or clutch. Double check for loose bolts. The mount is also suspect so you might as well replace it since you have a new one on the way.
thans for the info i know i double check everything with the car when put everything in torgued everything possiable but by dumb luck had a gut feeling that it was the trans mount and behold that was the problem so all fixed now but have other issues cant seem to find anything on tune for the speedo have hpt and cant figure it out just yet
Glad to hear the vibration is fixed. I believe the speedometer reads off the differential so unless you have changed the rear end the speedometer shouldn't be affected.
