Sweeping Gauges
Old 05-18-2009, 02:25 PM
christrusler's Avatar
Default Sweeping Gauges
This just started happening, the past couple days. At WOT, car loses power, the gauges sweep, like i just turned the key into the on position, after gauges sweep, car is back to life. Any ideas?
Old 05-18-2009, 02:30 PM
2001NBMZ28's Avatar
Is it a '99 and doing it on start-up too, along with the trip odometer resetting to zero?
Old 05-18-2009, 02:35 PM
Sorry i didn't give more details.
It's a 2000, no it's not doing it on startup. Haven't noticed the odometer going to 0
Old 05-18-2009, 02:42 PM
slvr98camaro's Avatar
i seem to recall this happening to someone on here, two different times
one time it was the alternator was bad, and another was the wire on the back of the alternator was dirty/disconnected, as were the battery terminals
check those connections first and clean them good and see if the problem is still there
it may be a bad battery, or an alternator that is about to go out.. but can also be bad wiring somewhere or a bad ground
Old 05-18-2009, 02:56 PM
car has new alternator, battery and starter all in the past week
Old 05-18-2009, 03:06 PM
did you have the problem before you did all of that?
Old 05-18-2009, 03:27 PM
no.. i checked all the connections to the new parts.
Old 05-18-2009, 05:15 PM
i did just install headers also. so, the rear o2's are not currently hooked up. COuld that be the problem?
Old 05-18-2009, 11:09 PM
anyone?
Old 05-18-2009, 11:13 PM
shtnfrds's Avatar
car so fast it leaves all electrical power behind. flux-capasitor mod next...
Old 05-19-2009, 05:41 PM
Michael02hawk's Avatar
A long short, but try checking out the Positive terminal post on the DRIVERS side of the engine bay.
Sometimes that nut can back its way off causing the wires attached there to rub, friction, heat up and cause wierd electrical problems...ask me how I know. :-)
Old 05-22-2009, 09:59 AM
i checked all the connections on the drivers side... they were all good.
Any other ideas?
How many "grounds" does there have to be ? I've heard both sides of the block, and both heads have to be grounded. Can these areas share the same ground ?
Old 05-22-2009, 12:21 PM
tording99Z28's Avatar
Well since it just started with the new parts its more than likely related. If you say you checked all the connections and they are tight then I would say its probably the alternator. Go have it tested and see what they say.
Old 05-22-2009, 01:14 PM
alt is brand new..and is good.
Old 05-22-2009, 03:11 PM
It doesn't matter if it is brand new, you can receive bad parts from any parts store. How do you know it is good?
Old 05-22-2009, 03:38 PM
I already had the alt tested
Old 05-22-2009, 03:47 PM
1Loudz28's Avatar
you have a lose ground somewhere, check the ones at the back of the heads.
Old 05-22-2009, 04:06 PM
Can i just install a new ground at the front of the head to test it out? Does each head, have to have it's own ground? Do these grounds goto the battery of the frame, or body?
Old 05-23-2009, 07:01 AM
There is a Ground wire up above the starter...dont miss that one when checking all your grounds. Since the starter was also changed out, its possible that ground got knocked around.
