the ground connectors was off at driver rocker panel and floor pan rail.Won't start
I took the ground connectors off at driver rocker panel and floor pan rail where front seats. I drove for 10 yards and the engine QUIT. I found the ground connectors, was disconnected. I put it back on. I tried start again and nothing crank up. The headlight and lamp works on.
What I should check on?
Bad PCM? Fuse blow?
Bad PCM? Fuse blow?
