anyway to disable daytime running lights?
i have a 2000 camaro with daytime running lights and i was wondering if there was any way to bypass it? i jus find it very annoying that i cant shut it off when i please.
Yes
Take your stereo out.
Locate small black box attached to firewall biased towards the passenger side of the car.
Take the box apart and locate the two larger sized solder points on the board and solder them together.
http://www.lightsout.org/disable.html
Yes
If I wanted to add a switch to turn on the DRL's. Would I simply go ahead and solder the switch into those two solder points, just not connecting them to each other. Just one end of the switch to one, and the other end of the switch to the other? So the switch is just acting as the "jumper".
