Strange ABS issue after 9" swap
Old 08-01-2009, 08:58 AM
Ironxcross's Avatar
Default Strange ABS issue after 9" swap
I recently put a 9" rear in my car, with 4.11s and a trac lock. I had abs reluctor rings pressed on to the axle for the abs. I also had the computer adjusted for the gears and other changes.
The problem is that the car sets off the abs light after about 1-2 miles of driving and it stays on. However when I let the car sit and start it up again.. the light goes off and then after 1-2 miles it sets off again!
Everything is hooked up and should work.. what is the issue?
Old 08-01-2009, 03:00 PM
Ironxcross's Avatar
anyone?
Old 08-02-2009, 09:29 AM
Ironxcross's Avatar
people have done this swap before and ran abs, I'm sure its something simple, does anyone have any pointers?
Old 08-02-2009, 09:39 AM
AFASTYZFR1's Avatar
Replace the rear ABS harness.
Old 08-02-2009, 11:07 PM
Ironxcross's Avatar
how would that fix it? it worked before.
Old 08-02-2009, 11:16 PM
donalr76's Avatar
Mine is doing the same thing. My 4-channel ABS worked fine before, but I figured my ABS rings must be different than the stockers to some extent. When you get it figured out let me know.
Old 08-02-2009, 11:17 PM
donalr76's Avatar
I have just installed a 9" with 4.30's to be exact...
Old 08-03-2009, 07:12 AM
AFASTYZFR1's Avatar
Is it a 3 channel? I was trying to chase down the same problem with my 9in. My rear ABS harness looked fine so I never replaced it. But after awhile I went to junk yard and got one for free. Turns out the plug that goes into car had connectors pulled out too far and didn't make a good connection. Now ABS works perfectly.
Old 08-03-2009, 07:17 AM
AFASTYZFR1's Avatar
I don't have 4-channel....but do some reading. I have seen threads where they talk about a shim or something to fix 4-channel set ups.
https://ls1tech.com/forums/search.php?searchid=8440440
Old 08-03-2009, 10:05 AM
99RTA's Avatar
Quickest way to fix it is get it scanned and see why its turning on the light.
