Sponsored by: CARiD
Streeing rack
Old Sep 9, 2009 | 01:46 PM
formula87's Avatar
Default Streeing rack
The rack on my 00 SS has a small leak, what do you guys do when the steering rack has developed a prob? can it just be repaired or just replace the whole rack?
Old Sep 11, 2009 | 08:12 PM
formula87's Avatar
anyone ????????????
Old Sep 12, 2009 | 12:50 PM
eseibel67's Avatar
I used to work for a rack rebuilder. It depends what you are doing with the car. The Lucas PS treatment will cure small leaks by swelling up the seals.
Of course the leak will eventually get bigger. It depends how long you are keeping the car. More than a year, replace the rack. Less, you might get lucky with the snake oil. I'm not to big an additives. I would be afraid they might actually damage the pump and hoses.
Old Sep 12, 2009 | 03:09 PM
99RTA's Avatar
Betcha if you just change the fluid it will stop leaking. Just buy a good brand like Valvoline etc. Mine did the same thing at 36k miles....after changing the fluid it never leaked again.
Old Sep 13, 2009 | 09:12 AM
formula87's Avatar
Keep'n it for as long as I can...................... Will probably try flushing out and replacing with new fluid.
thanks
Old Sep 13, 2009 | 09:48 AM
eseibel67's Avatar
Not sure how a fluid change could cure a leak unless the fluid has some special properties. Might be worth a try.
I also have a minor leak. My strategy is to keep fluid up until I can deal with it properly.
formua87: If you change the fluid and the leak stops, let us know what you used.
