changing headlights and fog lights
need help!!!!!!
i want to change my headlights and fog lights on my 2002 trans am....i got the bulbs but i cant reach the fog lights to change them, and how do i change the low and high beams...........help please
Re: need help!!!!!!
For the low/high beams just twist the bulb that is in there and it should pop out. When its out only a clip or two holds it in just take pliers and pluck the bulb out. For the Fogs you can remove the plastic undergaurd and just go in from the bottom. It's only 2 bolts.
Re: need help!!!!!!
ok i pulled the housing for the bulb out and it looks like its glued in.....now what, just twist and pull...?????and just to make sure the bulbs are 9005 and 9006??????
Re: need help!!!!!!
i tried to go under the car and change the fog bulbs but it was a lot of work... if it was a formula it would of been a whole lot easier. The best bet is to take it to the dealership talk to someone and let him either hook you up or let the mechanic do it on the side. let me tell you one thing... i did a brake lube test and changed the bulb and it took them 2 hours just to be done with it even with them raising the car up. Also you might wanna be careful about touching the fog bulb .. any simple grease or oil from you hand could go on it and burn you bulb easy. better watch out.
The stock bulbs are 27.5 watts ... i got 37.5 watt bulbs and i had no problems with them. people higher wattage bulbs like 50-110 watts burnt the stock lenses and some wires. Becareful about that... if you want the bulbs i bought email Leo at gameport@earthlink.net and he should still sell the bulbs I got with a whiter brighter look that is yet a safe upgrade.
good luck!
good luck!
