Suggestions on rattling center console
I have true duals on my Formula and with that exhaust comes more noise and shakes, especially with the stall. Everything is pretty tight inside the car except the center console. It rattles during various RPM levels. It's not loose, it just makes an annoying buzz. I can handle the drone and the loudness of the TD's but that console is really getting on my nerves. Does anyone have any suggestions on how to tighten it up or have come up with a solution? I know the quality of these interiors suck. Any tricks out there?
Save the manuals!
Check the passenger side cup holder. To do this, stick your hand between the center dash and lower console and press down on the cup holder. If that cuts off the sound, you'll know its it. The metal bar on the bottom of the holder rattles around a lot. (I haven't been motivated enough to fix mine yet. Some felt should probably to the trick.)
I think I have the rattling you may be referring to. I find if I push hard on the dash above the left corner of the glove box it dies down. However, I have no clue what it is or how to get to it. I did find that the rattling died down when I placed a rubber spacer in two different places. First I used some large fuel hose and placed it below the center dash in the space betweent the dash and the swing out cupholder. Just wedged it in there. the second spot i placed some hose was in the space above the radio and beneath the cental A/C vents. Just pop of the trim and then wedge some hose in there standing up. The bottom of the A/C vent has a funny slope so you have to be a little creative in determining the right size. I have thought about making a permanent spacer with a threaded rod that way I could adjust as needed when the temperature changes. This seemed to help a lot although it comes back on certain road surfaces. It's amazing how that little noise drives you nuts.....just have to cruise more with the window down, radio up, or at WOT!!!
still ahve the plastic sliders surrounding the shifter? Mine rattle like HELL. Went to take them out when slow at work one day.. but didn't want to lose my visual gear selector thing.
I put a thin layer of felt under just a few of the plastic sliders surrounding the shifter. That helped on some of the center console noise.
There is also a 'buzzing' coming from the plastic piece where the gear indicator is. It is annoying, and I haven't taken it apart to deal with it, but thinking that a very thin piece of runner under that plastic should help with that.
Just my .02
Just my .02
