Weird Popping sound
Weird Popping sound
Ok guys when at low speeds probably under 15mph if i apply the brakes lightly I can hear a pop in the front of the car although i cant pick out if its the drivers or passengers side (it may alternate) its definetley noticeable and even happens sometime when i let off the brake to get moving, but it doesnt happen everytime. I checked the calipers and theyre both tight the ball joints and bearings are all good. I dont think a tie rod is the problem because its completely silent when turning. Any ideas I was thinking a cracked pad maybe but I'm not sure.
Dan-
Dan-
Ball joints are usually the first suspect... BUTTTT i had the same issue, turned out the caliper bracket itself was a wee bit loose causing the caliper to shudder. Blue loctite FTW
Sorry guys I completely forgot I even posted this. How should I check the control arm bushing?s? The ball joints seem ok if I jack the car up and try and move the wheels up and down they dont budge and the car drives tight on the highway so I think theyre ok, and I keep thinking calipers tyoo but they seem tight.....
