Walbro 255Lpr Hi-flow Fuel Pump getting loud!
So I've had this Walbro 255 hi flow fuel pump in the car for like 3k miles and I just recently noticed it's getting loud. When I first installed it you couldn't hear it at all and now I'm wondering if it's about to quit on me or somethin. The car recently spent like 6 weeks without being turned cuz I was away for work so that might have had somethin to do with it! Anybody have a similar experience with these?
I would like to check the pressure it's pumpin out cuz I'm gonna be hitting the track soon and want to spray but I don't know how to do it myself. Any advice would be greatly appreciated guys.
O.K. The schrader valve fitting should be at the front of the fuel rails on the driver's side. It's got a plastic cap on it, although it may be gone by now. Get a fuel pressure gauge (I use a Hypertech 4004, but there are others) and attach it there. Key on, engine off, it should shoot up to ~58 psi, give or take, then begin to taper off slowly. Engine running, it should be in the low to mid 50s. Lower values, or a quick loss of pressure with the key off, indicate a problem.
If it is loud, but working correctly, It's just a Walbro. They are loud. There is a company called TREPerformance that claims their pump is not as loud, but I have never tried them.
Best of luck.
Best of luck.
