Sponsored by: CARiD
Can't go WOT...
Old Mar 20, 2010 | 07:54 PM
feelnlo's Avatar
Default Can't go WOT...
I noticed my car is not opening the throttle linkage all the way to WOT. I adjusted all the cables as tightly as they would go, using the plastic threaded sections in the cables. There is no binding or anything under the gas pedal, but the linkage on the throttle body will not touch the throttle stop when the gas pedal is on the floor. Its about 1/8 inch from touching. I've read an article about how to actually increase the amount of WOT beyond that throttle stop by grinding the TB, but mine won't even touch it stock. Also, after I messed with the throttle cables, my cruise control stopped working.
Ideas?
Old Mar 20, 2010 | 08:19 PM
LS6427's Avatar
Need a new cable.
Old Mar 20, 2010 | 08:28 PM
feelnlo's Avatar
Car only has 25,000 miles on it and it needs new cables? lol
There is more than one cable due to the cruise control or traction control. I'm not sure exactly what that cylinder shaped part is with the gears, but the cables run in and out of it.
Old Mar 20, 2010 | 08:33 PM
LS6427's Avatar
Take a picture.
My friends brand new Viper had a stretched cable after 4 months. Just a maybe........
Old Mar 20, 2010 | 08:42 PM
feelnlo's Avatar
Yikes. Yeah i might have a picture on my computer. Im not at home right now with the car. Let me check
Old Mar 20, 2010 | 08:55 PM
feelnlo's Avatar
[IMG][/IMG]
Old Mar 20, 2010 | 09:20 PM
LS6427's Avatar
Thats the cruise control.....
Old Mar 20, 2010 | 09:34 PM
feelnlo's Avatar
Yeah. Wasn't sure if it had anything to do with the traction control also.
Anything I should check on this unit as far as why my cruise stopped working after I adjusted the slack in my cables?
