weird sound coming from engine (video inside)
Old 04-25-2010, 03:04 PM
Demon440's Avatar
Default weird sound coming from engine (video inside)
sounds like the right side, maybe toward the rear?
http://s629.photobucket.com/albums/u...t=IMG_0802.flv
Old 04-25-2010, 03:17 PM
monte383sbc's Avatar
try taking ur belts off first and run it and see if the noise goes and and go from there but dnt run it to long
Old 04-25-2010, 03:26 PM
pheer's Avatar
if it's not the belt, that sounds like something is not getting lubricated....
Old 04-25-2010, 04:41 PM
Demon440's Avatar
oh yeah one more detail. you cant hear it in the video but this sound will go away and come back randomly.
Old 04-27-2010, 02:03 AM
BFarrier's Avatar
I have the same noise in my 2000 Z28. it only happens when the engine is still warm after a drive and starting it up and it will make sound for less than a minite and then go away. any luck with that yet?
Old 04-28-2010, 09:31 PM
05c15builder2009's Avatar
it sounds like altanater bearings or water pump bearings...
Old 04-28-2010, 09:51 PM
u can also use a screwdriver or piece of wood and start putting it in diff spots on the motor with ur ear up against the screwdriver that will help u pin point where the noise is coming from.. good luck
Old 04-29-2010, 12:26 AM
BFarrier's Avatar
does the sound go away on your car? after about a min or so? mine does and any luck yet to what it maybe?
Old 04-29-2010, 08:52 PM
Demon440's Avatar
I haven't messed with it any, still happens and it normally happens more when cold and will suddenly go away. After driving it may come back. But it ONLY happens at idle.
