Driver window fast as hell...now pass. window wont budge
uh-oh. How did you do this? By chance, did you move the felt pads on top of the door?
If I remember correctly, you have to adjust them with the window shut. They should not contact the glass when its in the full-up position. They are only there to stabilize the glass as its moving up/down. Once the glass starts to go down a bit, they push the glass up and off the weatherstripping.
If your window is rattling when down, you might check for the rubber block that should be slotted in to the bottom of the inside of the door. If its out of place, that might be letting things get loose.
