Check Guages/Car wont start
I have a 2000 T/A that runs great. It only has about 25k miles on it and i only drive it when the weather is nice, otherwise it lives in the garage. I took it out last night and it started up just fine at first. When I got to my destination and shut it off, then tried to start it back up all it would do is crank. After shuting the key off a few times then turning it back on it finally fired up. Then the next time i shut it off it wouldnt start at all, all it would do was crank. A guy that knows a lot about LS1s came up and noticed that the check gauges light was on, he pulled of the fuse panel, pulled my guages fuse, put it back in, and it fired right up. Did this several times and it works everytime, does anybody know why?
Still Having this problem only now its worse, pulling the gauges fuse no longer works and she shut off on me at about 3/4 throttle doing about 90 on the highway the other day (in mexico of course). When I coasted to a stop I got out and pulled the main ignition fuse under the hood and let it reset then it started, but the next time I tried that it didnt work. Dealership doesnt seem to have a clue and charged me $500 for a BCM that I obviously didnt need. Anybody have any ideas?!?
Did you take it to WK or Lotspeich?
holy hell, get back to the dealer and tell them the BCM didn't fix the problem. It's called a re-check and they need to figure out the problem or give you back your money....I would be pissed.
Damn I didn't read that at first. Hopefully its not the same shop that charged you for a BCM. A faulty BCM would cause no fuel which you said you have.
So you are 100% sure you are getting fuel. Have you checked for spark?
How did you verify that the fuel system is getting the proper amount of fuel or fuel pressure?
I went through this and found it to be my ign. relay, but mine never shut off while going down the road. You can swap relays with the A/C and see if it changes anything.
Can anyone give a good reason of why these sensors go out?
I just thought my car did this in the cold weather because the previous owner didn't take care of the car at all and the high mileage.
But OP's car only has 25k miles on it. Are these sensors a wear & tear item?
Dealer also told me I would need the computer reflashed for $125 to turn off the ses light. I unhooked the battery, the light stayed off, car still runs fine. Dealerships.....
