Installed new window motor and found this rubber piece..what is it?
Old 09-01-2010, 09:24 PM
02SLPTransAm's Avatar
Default Installed new window motor and found this rubber piece..what is it?
I was replacing my window motor today, I followed the instructions from shbox.com which is very helpful. Well when I was done I had lost a screw and was trying to find it inside the door when I found whatever it is in the picture I attached. It is a rubber piece that was just laying inside the door on the bottom about 3/4 of the way down the door. Of course I have no idea where it came from or what it is. I am assuming it goes somewhere inside the door but where? Any info would be great.
Attached Thumbnails Installed new window motor and found this rubber piece..what is it?-dscf4247.jpg   Installed new window motor and found this rubber piece..what is it?-dscf4248.jpg
Old 09-01-2010, 09:36 PM
Spartan7's Avatar
That's the window stopper. It attaches to the bottom of the door and stops the window from bottoming out.
Old 09-01-2010, 10:49 PM
So the small lip at the bottom of the rubber piece will attach to some hole in the bottom of the door? I am assuming if I feel around down there I'll figure out where it goes? Am I right?
Thanks for your help.
Old 09-02-2010, 06:38 AM
Save the manuals!
wssix99's Avatar
Take the speaker out and you should be able to see it. It slides into a slot cut in the bottom of the forward part of the door.
Old 09-02-2010, 08:37 AM
Ok thanks, I still have it all apart because I ran out of daylight. I appreciate your help!
