99 z28 camaro wont start
my 99 z28 camaro was driving just fine until randomly it quit starting all toghter when i woke up to go to work. i replaced the starter and it would crank up just fine unless it sat out all daythen all i would need is a jump from another car and it would start up again. well it has stapped starting again and i have replaced the battery, alternator, ignition and starter relays, crankshaft sensor, and starter. i have tried putting it in neutral and it still will not start. it cranks just fine but just will not start for some reason. the fuel rails for the injectors have pressure bc i bled them for a sec and it sprayed out. im completely out of ideas i need help if yall can...
In my experience, when this happens, it's back to basics: air, spark, and fuel. Check to see which one's not happening and go from there. It probably is a relay like DVS suggested, but if you are getting spark, I would see if the car is throwing any codes.
EDIT: Actually, it may not be a bad idea to check if it's throwing codes now, that way you know what to look for.
I have exact same issue. No spark, no codes, pressure at fuel rail, turns over fine, no security light. Swapped crank sensor with known good one, and swapped relays. Car is stock 2001 T/A WS6 with LS1/auto. Help!
Thank God...I swapped the ignition and starter relays and the car started. I don't know if I brain farted and swapped the wrong ones last time or not, but works great now. Must have been a simple case of oxidation.
i was jsut checking everything today and noticed on my OHM meter that i had now power going to my Mass Airflow Sensor. i ran a wire directly to the battery and then it cranked up just fine and runs like a dream again.
