power steering pressure line hose
Old 12-26-2010, 02:11 PM
romeric's Avatar
Question power steering pressure line hose
whats up everyone? does any one know how to change the power steering pressure line hose? how hard is it? i need to change mine, because the hose was hitting with the serpentine belt and it cut the hose enough to leak all the power steering oil out. would i need to drain all the coolant out? it seems the hose connects to a pipe for the raideater. are ther any special tools i need? does any one have a step by step guide to do it? oh its a 2000 trans am ws6. thanks in advance.
Old 12-26-2010, 10:13 PM
eseibel67's Avatar
That's not the pressure line. The return line runs through the PS cooler.
The hose can be replaced without any special tools. If I remember, the return line is held on with hose clamps.
Old 12-27-2010, 01:05 AM
patSS/00's Avatar
The line's held on with clamps (those horrible spring type, replace with screw type), but you'll probably have to cut it lengthwise with a razor to get it off the fittings. The main PITA part is getting the new hose pushed onto the PS reservoir fitting.
Old 12-27-2010, 08:54 AM
Save the manuals!
wssix99's Avatar
Since that hose is a low pressure hose, you could probably just use a double-ended barb to splice the pieces back together if you want an easy fix.
Can you post a pic? Something else isn't right. That hose shouldn't be able to hit the belt.
Old 12-28-2010, 05:27 PM
LS6427's Avatar
Yes, pictures. You have a factory power steering fluid cooler, don't you?
If yes, you need to remove that thing and replace it with an aftermarket cooler. Tales 15 minutes and a philips head screwdriver.
Quick Reply: power steering pressure line hose
