Sponsored by: CARiD
problem with horn.
Old Jan 30, 2011 | 12:59 PM
Chaos07's Avatar
Default problem with horn.
ok guys help me out, ok ive checked all the fuses and they ar good. the horn honks when i use the key. but i have to like really hit the horn to even get it to honk n its just a little burp. im thinking maybe i need to replace the spring if there is one or something. help a guy out here lol insepction coming up soon.
Old Jan 30, 2011 | 01:37 PM
1998 B4C's Avatar
Originally Posted by Chaos07
ok guys help me out, ok ive checked all the fuses and they ar good. the horn honks when i use the key. but i have to like really hit the horn to even get it to honk n its just a little burp. im thinking maybe i need to replace the spring if there is one or something. help a guy out here lol inspection coming up soon.
I had an issue with mine. Only one out of two horns worked and sometimes sporadically. I replaced the horn with a new set and viola', it works perfect and louder. It may not be your horn button, so try another horn you know works first. Hope this helps.
Old Jan 30, 2011 | 01:41 PM
Chaos07's Avatar
do you know which horn it is ro replace the top 1 or the bottom 1 haha, i looked at it today n the top has the wires going to it and the bottom 1 has the wires jumped from the top to the bottom
Old Jan 30, 2011 | 03:50 PM
Chaos07's Avatar
i fixed it, went to autozone got a new horn but the bracket hole was 2 small for the new horn so i had to drill it out a bit more. and had to use quick disconnects on the 2 small wires to connect to eh new horn. and now it works good.
