Engine misfiring
I thought it was the fuel pump as I only read 34 psi when the car was running, would jump to 44 psi when the vacuum line to the regulator was removed, which was good. Spec for the fuel pump is 41-47 psi, but thats when the key is first turned on. I get 40 psi, which I figure 1 psi low is probably more related to accuracy than issue.
So what the heck is causing my misfire? The issue seems to get worse when it gets warmed up. It is most noticable when sitting at idle in gear or when accelerating.
I was thinking it was related to the egr, but it is the digital model on this one and without a tech 1, I cannot do a test on it. Then again, I dont think its quite in closed loop when the issue starts either. It get noticable about a minute after the car starts running.
So, I thought to myself, what is different here. I noticed that when I turned on my headlights, it felt like it missed again. the volt meter dropped from 14-13 and went back up and ran normal again. I sat in drive with my foot on the brake and on occasion it would drop miss and the volt meter would drop and come back. Could this all be related to ground? I question this because I replaced the fuel pump (as I thought it was the issue) but it did not fix the issue. I checked voltage at the connector to the pump and it read 8.6 volts. So, i thought the wiring to the pump was the issue. I went through and checked voltage at the relay and it had only dropped .5 volts from the battery. So, I went back and check voltage at the connector again and this time it was the same as the relay. I back probed the connector with the engine running and it was still battery voltage.
Other items I forgot to mention. about 2 days prior to this happening, I sea foamed the thing. Not sure that it would have caused all this.
About 9 months ago, I added a remote start system to the car. It is still functional, so I wouldnt think its causing an issue. If it was causing the issue, would it be related to the pink ignition wire it is tied into?
Is it possible the computer has **** out?
