Doesn't want to turnover? Help? Okay I just recently started having a problem with my car (01 ws6) not wanting to turnover until I turned the key at least a couple times. I figured I had a bad battery which I took to O Reillys and had it checked and sure enough yes. I then bought a new battery and put it in. However it still usually does not want to turn over on the first turn of the key. Am I having ignition problems? |
Anyone have a little friendly advice? |
your starter probably has a dead spot. i would replace it. |
Alright Ill get it checked out tomorrow to make sure. Figures, after I get a new battery I thought it might be something with the starter. Thanks for the help |
plenty of posts on here about this. Many many things to try. I'll give you another though, the starter relay. Try switching it with one of the fan relays. |
Could be several things: Ignition relay Fuel pressure problem Cam position sensor. The older these cars get the more problems they have |
| All times are GMT -5. The time now is 07:55 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
