1999 CAMARO SS back fires just wondering if its normal for my 1999 camaro ss to backfire when its cold |
no, it probably needs a tuneup. |
its only when it cold though just bought it 2 weeks ago and stored it |
any codes? |
no codes |
plugs might be worn out. hard to say. |
what kind of exhaust set up do you have? Also do you still have your EGR/AIR hooked up? When i bought my camaro (stock) it did not back fire at all After installing longtube headers and True Duals, it backed fired some. Now that i removed EGR/AIR (after LS6 intake swap), no back firing like before. only on occasion. Thats my experiance with "backfiring" atleast. |
i think its hooked up not sure but i will get it checked out in spring thanks for your imput |
at what mileage do they recommend tune up spark plug change? |
If you just purchAsed the car I would go ahead and change out plugs, oil, trany, and re end. Maybe radiator flush if need to be. You never know when the last time they been changed. I wOuld put synthetic oil, I use castrol synthetic than change it out every 3000miles at the most. |
Originally Posted by D14HUGGER.ORANGE
(Post 15558083)
If you just purchAsed the car I would go ahead and change out plugs, oil, trany, and re end. Maybe radiator flush if need to be. You never know when the last time they been changed. I wOuld put synthetic oil, I use castrol synthetic than change it out every 3000miles at the most. i think ive heard its from 6k-8k |
Yeah it is. Personally I dont like running my motor past 3k without an oil change because of the cam work and mods, my ls1 is a thirsty son-of-abit*h...it keeps it running healthy |
What brand spark plug is recommened? |
Almost like clockwork my '02 SS backfires a lot between my first gear shift of the day, then almost never again unless I ride down a particular gear from high rpm for a while then disengage the clutch. I only hear it (maybe even only get it at all) when the e-cutout is open though... |
© 2024 MH Sub I, LLC dba Internet Brands
