Car Will Not Turnover!!! My car will not turnover. The relays click and that is all. It is not VATS because I got it deleted. The relays are new and I'm about to go get the starter tested. What else could it be?? It use to only do it every so often. Once a month or two and I would just turn the key a few times then it would turn over. Then it got to where it would do it after it was ran hard and I would have to turn it for 5 minutes till it turned over. Now it just wont crank what so ever. The dash lights come on then go off including security. The only lights that stay on are ABS INOP, Brake, Service engine, and service engine soon. |
Ok.. well I got my starter tested and it passed but the part of the test that tested to solenoid said N/A. Could the Solenoid be the problem? |
Yes it could be the solenoid or Starter relay? Check to see if you are getting voltage to the starter then across the starter with the key in the start position. I would use a simple 12v test light to do this, if you are not getting voltage to the starter check the relay, if you are getting voltage to but not across the starter it's prob. the solenoid. make sure your battery is good, a dead or shorted cell can show good and be bad! And a clicking relay is not always a good relay. |
Originally Posted by Anthony Williams
(Post 15640809)
Well it took a few more days then planned haha. My buddy was pretty busy this week so I called and asked him a few questions. I went ahead and tried the test light and there it was, the power was definitely getting to that purple wire (whatever that means haha). Changed the starter and now it cranks every time without flaw. Thanks Anthony! |
No Prob, Welcome back on the road. |
© 2024 MH Sub I, LLC dba Internet Brands
