Cant pass 70 mph!!!!!!
Haha no guys mom doesnt touch my car eventhought she probly would do something like thst haha.
But the code I got was MAF wiring bad ground. And another about wiring also. Guna check that out wen I have free time nd hopefully fix the wiring nd go from there. I cleaned the MAF but guna try another one see what happens. Thanks alot guys
O2ws.sik do you know how the guy found out the cable was,getting stuck?
Cuz after it bogs I tried stepping on it and the pedal was rock hard wouldnt let me step on it
When was the last time you cleaned your TB? Sounds like it stuck.......or maybe the ASR or whatever was being an *******? See if your TB has black/brown buildup around the throttle plate, may take of that problem but doubtful it will affect anything else.
Yes look to where it is at this is what is wrong 99% sure if the pedal is hard its not letting it pull all the way. Turn on the car have some one rev it and try to push the tb wire back to wot. You mayne able to see where its at worst thing you have to get a new line. His was a 2004 gto.
I barely read this today I will try the tb line thing tomoro hopefully. I really do hope this is the problem im tored of this crap! Thanks again. Ill let u guys know what happens
I had a problem similar to this one time. Pedal didnt get stiff and didnt really bog and slow down but didnt accelerate very good at all, smoked, and generally ran like ****. It ended up being a 20 amp fuse that supplies power to IAT, MAF, O2's, MAP, TPS, and pretty much every other sensor that makes the car run. Replaced the fuse and started the car and let it sit and even itself out. Smoked like a diesel for like 10 minutes but then it straightened itself out and has run great ever since. Just one more quick, easy thing to check.
Captain Double Post
go pick up a new computer and give it a shot. if it doesnt fix it just return it.
#34
Haha alright guys I found the problem! Soo the other day my friend gave me a set of zo6 wheels! I bought tires and put them on and passed 60 no problem. I didn't. Know these dam cars were soo smart! I had the same size tires in the rear jus diff brand that was the problem. Thanks for all the help.
#38
My car did the same kind of **** when I was driving it home for the first time... hesitant, sluggish and had poor top end.. did a full tune up and when I went to check the MAF, it had pieces of a damn bird in it... filter was filthy but in place... had feathers, a couple of bones and a ****** foot in my MAF screen.. No Joke.... descreened and used carb cleaner on TB and maf.. ran like a bat out of hell afterward...
