headlight motor...epoxy or ABS glue
Old 02-05-2012, 05:13 PM
FCar2000TA's Avatar
Default headlight motor...epoxy or ABS glue
I"m swapping out the gears and I have some epoxy, but would ABS glue be better????
Old 02-06-2012, 11:01 AM
Save the manuals!
wssix99's Avatar
No, because the housings are not ABS.
Even though they are not ABS, I tried it anyway and it was a horrible failure.
Even the epoxy fails to keep the covers on sometimes. I've since moved on to Cardone motors, which have great screw-on covers. The wiring was crap and I had to re-build all the connectors/terminals, but that is a different story...
Old 02-08-2012, 09:25 PM
great421's Avatar
IMHO - I would not epoxy them unless your new gears are metal (Brass / Al) - if using plastic "Help" section replacement gears, then they will fail just like your originals.
Old 02-09-2012, 09:38 AM
Save the manuals!
wssix99's Avatar
Newsflash - the metal gears fail often, also. The real problem is with the motor attachment to the housing. If its loose, it will tear up any material put in there.
Quick Reply: headlight motor...epoxy or ABS glue
