stock injectors? confused and where to buy
I have a LS1 from a 01 Camaro SS put into a 80 vette. I think a few of the injectors are bad and leaking back into the engine after it stops running. I am looking for stock injectors but there seems to be hundreds of them out there and price ranges like crazy.
I just want stock injectors that are not knock off cheapo going to break down kind.
Even my local auto store have 15+ "universal" injectors.
Thanks for the help
Thanks for the help
You can try FIC...Fuel Injector Connection. They'll test, clean, replace, flow your injectors.
There are other reputable vendors which you can find in the Fueling & Injection column on LS1Tech. You might try placing your question there.
Also, try the Parts for sale column.
Thanks everyone for the info! I think the fuel system is coming along now. I don't want to do a re-tune at this time but a friend has some stock injectors I can test with and see if that fixes the problem. If not I will be giving FIC a call.
Thanks again!
Thanks again!
