Outside of front driver tire wore VERY fast, any ideas?
I noticed the outside of my driver front tire was worn bad compared to my other tires, so I switched it out. Not even 1000 miles later I'm noticing the same pattern on the new tire. It hasn't had an alignment in a while, it doesn't pull too bad but it's not perfect, do you think the alignment alone could wear the tire that fast? Or should I be leaning towards the tie rods / suspension? Thanks
