Power steering loud and weak at idle
Good Evening,
I had my power steering pump replaced a year ago. Now that I have put my 275/40 R17 tires back on the pump is louder and barely helping when I am driving in a parking lot. Specifically when I try to cut it to get into a parking spot.
While I'm driving on the road it seems fine, but it is only when I want to park that it seems to be an issue. Is there anything besides replacing the pump to check?
I have replaced the belts and the belt tensioner recently so I don't believe those are the issue. When I had my winter tires on (225/40R17) it wasn't a problem all winter. I did notice it before I changed to winter tires, and it is back.
It is only a problem with my sticky wide 275/40R17 tires. Is it a weak pump? Does it have anything to do with the idle speed?
same here. i have the stock wheels and the stock tires, i used to drive with 17" wheels. when i installed the original wheels i started to hear that noise. it only happens on low RPM when the engine is warm.
Follow Up
I did a few things that seem to have helped. I'm not sure exactly what helped the most.
1. Used my predator to up the idle speed by 100 RPMs
2. I replaced the tie rod ends and wheel hubs on both sides.
3. Added extra power steering fluid.
It is still loud but I haven't had to use extreme effort to turn the wheels since. Hopefully this helps.
