will 99 and up knock sensors work? i have a 98 computer and harness with a 2000 motor and i need to replace the knock sensors, will the 99 and up sensors and harness work with my set up? |
the answer is yes with the correct harness but................if you have a 2000 motor you already have the 99+ sensors. |
I have a 98 car. I put in an 04 LS6 motor from a Caddy. I bought the newer knock sensors and sensor wiring harness. Everything works just fine and mated up to the existing 98 harness in the engine bay. |
Originally Posted by LS1121
(Post 16714474)
© 2024 MH Sub I, LLC dba Internet Brands
