Removing body wiring harness
I'm trying to remove the body wiring harness at the driver side firewall right next to the brake booster. It's a gray/black connector and looks like it should unplug there but I'm not 100% sure and I don't want to break anything.
I'm going to try to reroute the harness out of sight to clean up the engine bay durring my swap.
Thanks for any help!!
That's not a plug. The engine bay and interior I/P harnesses are connected by a large rectangular plug next to the steering column. You can see it on the left as soon as you take off the knee bolster, it has a single hex bolt in the middle. Loosen the bolt and pull the connector apart.
Ok it looks like a plug but i knew I wasn't doing something right. So I can take it apart my the column and feed it back in to the engine bay from there?
Just want to re route it out of sight. And cut out the circuits I won't be using.
