bank 1 lean and both sensors low voltage Helps??
I recently had a shop pull the motor and do an overhaul ony 99 Trans Am. Service Engine light was not on. After I got the car back I put about 250 miles on it and the SES ligth came on so I used Oreilleys code scanner and it coded bank 1 lean. Bank1 sensors 1 and 2 both read low voltage with separate codes. Curious as what would cause this on just one bank? Exhaust leak of some kind on that side? Did some searching and could not find anything on both sensors low voltage. Thanks
So just and update..
Coolant level is steady, not low at all and has stayed that way after several hundred miles.
There is moisture under the cap and a milky residue in the filler neck. The dipstick has milkshake on it and the dipstick tubes looks nasty inside of it.
Mechanic that did the overhaul said to drive it to 1000 miles and change the oil...
Doesnt seem like a good idea but I guess I will.
Milky dipsticks are never good! I think that you have a serious problem. Such as leaking head gasket or worst case scenario cracked head or block. You could try some block seal? Or better yet take it back and have them pressure test it.
when i first took it to have the engine overhauled the milkshake was brownish/orangeish
now its just white. he thinks it may be some extreme condensation/pcv system problem
ill update when i know more
Try this, open the radiator cap and have someone turn the car on. Check for any bubbles that float up in the coolant. If bubbles show up, you might have a blown headgasket.
That fact that he had a milkshake dipstick before the overhaul scares the **** out of me! I am thinking cracked liner.
