Bad Oil Leak, NEED HELP!
I recently bought a 2002 z28, has 79k miles on it and has a very serious oil leak, today i pulled off the intake, replaced the valley cover gasket, and oil pressure sending unit, but i was wondering before i put it back together if any of you thought it could possibly be the camshaft position sensor, the sensor including the inside of where the connector plugs in was soaked in oil, and iv read that if this was to leak it would run inside the bellhousing which is what im experiencing.. Any help or suggestions would be appreciated, if none of this is it i guess i will move onto the rear main
Thanks
Thanks
