Check Gauges light
Check Gauges light
Different than the Service engine light, the check gauges (in the bottom left hand corner of the cluster) flickers faintly (enough to where you can't see it during the day, only at night) when I go WOT, with or without downshifting. I believe the higher the RPM the greater the flicker... kind of hard to watch when you need to shift lol.
Any ideas? I thought it was the knock sensors, so I upgraded to the newer style sensors/harness, which needed replaced anyway. Also put some NGK TR55's in in replace of a delco iridium, still no go. Maybe wires? I figure its an ignition issue, but am not really sure.
Yeah, thats the problem. The only other time I've seen it, was when I put my headers back on and cracked a spark plug, and the spark was shorting out through the ceramic.
LS1Tech Administrator
Received 1,488 Likes
One of the gauges is showing a value outside of what is considered the "normal" range.
Since it's just a flicker, I doubt it's due to low fuel. Keep an eye on your volt meter next time you see it flicker. I had a voltage issue once at higher rpms too, and would see a faint flicker from that light...then I noticed that the volt meter would dip down low during the flicker.
Correct.
It took me some time to notice the quick dip in voltage when this happened, at first the only thing I noticed was the slight flicker of the check gauges light. The rest of the time my voltage was reading absolutely perfect.
I discovered that I could reproduce the condition just by power braking the car in my driveway. After some testing and parts swapping, I finally discovered that contact with this ground wire was apparently the issue all along.
