Whats up with my key fob?
Fellas,
Hopefully you guys can help me out. My one and only key fob for my Ws6 finally went to crap. None of the buttons work. So i lock the car from the inside, and have to hurry and start the car before alarm goes off.. Pretty annoying..
So i picked up a new battery from autozone. It worked fine, then when i got home, same thing. It pretty doesnt work.
Just wondering if anybody had any tips on how to fix it without heading to the dealership. Thanks..
I don't know if I've every owned a fob that didn't require reflowing the solder joints at some point. With the battery cover off (if it doesn't use anything on it for contact), press around on the battery some to put pressure on the battery clip and see if you can repeatedly get it activate. If it works it could just be a cold joint come loose.
