key on, no lights when cold
weird issue.
When its cold outside i go to start my car 02 z28. turn key to run postion no dash lights come on and it wont start. this only happens when it is cold outside. turn key to on postion wait for 10-30 secdonds or so dash lights come on and it will start.
when it is warm outside turn key to on position and dash lights come on and it starts.
very odd.
I have a good optima battery, and connections are good.
I replaced the ignition relay under the hood.
any ideas?
very odd.
any ideas?
mine did this last winter only difference was it started but i had absolutely no DRL ,Nightlights, or spedometer cluster .....I took it to the chevy dealer and the maintence head said he didnt feel confident any of his mechanics could fix my 02 TA .......anyway it ended up being a bad ground or a ground connection that needed to be tightened they had the car for 3 days......check grounds
I cannot find the external ground for the PCM either.
WHERE IS IT?!?!?!
The Helms manual shows the actual locations of most of the grounds (NOT just the schematics), but NOT the #110 ground.
WHERE is this??
WHERE IS IT?!?!?!
WHERE is this??
