ABS, Brake and ASR lights coming on at same time
I have an '02 SS Camaro and recently the ABS, Brake and ASR lights pop on while I'm running. When I shut the motor off for about 15 seconds and restart it they go off as normal. Any thoughts would be greatly appreciated.
Thanks for your help - the ABS wheel sensors are the wires with a connector on the back of the rear wheels correct? I got under and located them yesterday but need to get the car up to pull apart and try to clean. Did you have a scan done to locate the electrical part problem of the ABS module?
Was near the Chevy dealer today when lights popped on so took it in. Codes were C0896 which was supposedly possible weak battery and C0550 which was bad electronic brake control module. EBCM is rather expensive.
