voltage guage on cluster reading wrong??
Whats up guys my cluster voltage guage is wrong compared to my volt meter cars a 2000 z28 , is this normal because it scared the crap outta me on my way home its was reading 10 volts on the cluster and the lights were diming on the cluster and my blinker was extremely slow , as of rite now ive had the car running for about 20 25min and its charging 13.9 steady on my volt meter and mu cluster is reading 12
Any help will be greatly appreciated
LS1Tech Administrator
Received 1,488 Likes
I don't think it's reading wrong, I think you have some sort of voltage loss at or near the cluster. You mentioned diming lights and slow blinker; those things would not be happening if it was just an erroneous reading by the stock voltage gauge.
Where are you reading the 13.9v from? Directly at the battery? Or alternator?
Well, if your lights were dimming and the blinker was low.....you certainly had a charging issue at that time. The volt gauges on these cars are actually pretty accurate from what I've seen in 15 years. M better than others, some probably way off. But most will read right around the 13 mark when everything is working properly.
