weird road noise..maybe bad wheel bearing?
Old 02-17-2014, 01:11 AM
quiet_storm98's Avatar
Default weird road noise..maybe bad wheel bearing?
I have this loud droning/rubbing noise coming from my car mainly if I go faster then about 25-30 mph. I noticed that if im on the highway and the road curves left it gets really loud but also gets louder when I have to turn the wheel to the right just not as loud as when I turn the wheel left. If im turning at low speeds I hear nothing and even sometimes if im driving straight I will hear the noise but not all the time which is weird. I haven't tried the method of holding the wheel at 12 and 6 yet but im thinking its either the two front bearings or my tires. Anybody have any insight on this?
Old 02-17-2014, 01:32 AM
xenergyx's Avatar
probablly bad rear bearing.....pretty easy to do just kinda messy parts/oil maybe 50$ if you do it yourself and theirs no damage to the axel shaft otherwise its more like 200
Old 03-09-2014, 12:15 AM
Well finally got a chance to get the car up in the air. The front passenger wheel had some play in it so i just ordered a new hub assembly for it
Old 03-09-2014, 12:29 AM
jsteele90's Avatar
yeah usually the loud droning is a wheel bearing.
Old 03-09-2014, 01:57 PM
jt_2002_ta's Avatar
yes,bad wheel bearing. ive replaced 3 of them this winter. 2 on my truck, and one on the wifes saturn. gm hub assembly's are notorious for going bad.
Old 03-10-2014, 09:25 PM
What's odd is my previous camaro never had this issue and it had 175k miles but o well you never know when these things will go bad
Old 03-20-2014, 04:16 AM
chrysler kid's Avatar
Mine sounded exactly like brake pads squeaking, then it over heated the sensor and threw abs codes.
Quick Reply: weird road noise..maybe bad wheel bearing?
