Car won't turn over. Okay, so I have a 02 z28 (m6) and when the car sits in the sun for a long while, I'll unlock the door with my key, the alarm will start to go off, and the car won't start.. I'm thinking it could be something with my starter because the car won't even turn over. But why would this only happen when the car sits in the sun? Any suggestions would be greatly appreciated.. |
Your alarm is still engaged it won't let you start the car mine does it as well some time y I have no idea |
Originally Posted by 1slow_Z
(Post 18162344)
I'll unlock the door with my key, the alarm will start to go off, and the car won't start.. |
I have stock alarm and sometime wen I put key in ignition it still goes off |
Originally Posted by wssix99
(Post 18162664)
If this is the stock alarm, you have to put the key in the ignition to turn the alarm off. Do you have VATS disabled or anything like that? Is this a stock alarm? |
Originally Posted by chevybayboy
(Post 18162498)
Are you turning the key our just putting it in? I recall that maybe you have to turn it at least one click? If the alarm still goes off when you turn the key, it sounds like something in the BCM isn't working to deactivate the alarm on the key turn event. |
(Post 18162849)
Does it take a while for your car to start up again? |
(Post 18162941)
Anyone else?? I'm still having this issue, and its getting pretty annoying.. |
Okay so I've been reading around on the forum and I've come to the conclusion that it is most likely vats that's doing it, so I'm gonna get my buddy to take it off with hp tuners today, and I'll post up the results later... |
| All times are GMT -5. The time now is 11:27 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
