Hub bearing assy
When driving at about 40 MPH, gently turn the wheel left, then right, then left, then right to change the load on the bearings.
If you hear a faint whub-whub-whub-whub-whub-whub that changes in intensity as the weight of the car changes sides, you have a bad bearing. This test will easily identify which side is causing it.
Another method is to jack the car up and feel for play, there should be much or any.
