RTV spatter inside Throttle Body?
Old 08-06-2014, 07:34 PM
Wreckless123's Avatar
Default RTV spatter inside Throttle Body?
Just got the car this weekend and from what I can see its pretty stock. Its a 99 SS Camaro. I pulled the air box because it seems like the lid not align very well and when I did that I looked inside the TB. There looks to be RTV spatter inside the top of the intake. Does this make any sense to anyone? Thanks for any help.
Old 08-07-2014, 03:07 AM
Anyone?
Old 08-07-2014, 04:21 AM
flyingbrick88's Avatar
Crazy. I'd have a look further up stream on the intake. I'm betting there is a hole and someone has attempted to seal it.
Old 08-07-2014, 07:36 AM
If it was upstream I would think it would not show in the TB because the flow of air is into and past the intake. I was wondering if someone put RTV on the TB when they installed it and it dripped into the intake and the car was started when the RTV was still soft. Only thing I can think of.
Old 08-07-2014, 09:47 AM
dailydriver's Avatar
This seems like the most viable explanation.
Old 08-08-2014, 03:39 PM
Fireberg's Avatar
Is the EGR tube installed?
Perhaps the previous owner removed and plugged with RTV.
The EGR tube is a metallic tube that enters the top of the throttle body, just behind the throttle plate. I can not tell for sure if it is there or not from the photo.
Old 08-08-2014, 08:45 PM
jrpimp00's Avatar
^^EGR enter the top of the manifold. OP, pull the TB and check to see if RTV is behind it, there is no need for it if the gasket on the manifold is good
Old 08-10-2014, 04:49 PM
The pic looks like there IS a cut/trimmed (as per the 'free mod') EGR tube present, but the p.o. could have still used RTV on it to seal beyond the o-ring gasket.
Old 08-11-2014, 01:56 PM
big_g's Avatar
This is the reason I personally try to avoid RTV, when possible.
Sharp looking car by the way!
Quick Reply: RTV spatter inside Throttle Body?
