1999 camaro ls1 6speed wont start just clicks
Hey every one I have a 1999 camaro ls1 that won't start it has a new battery new alternator took starter to get tested pass 4 times in a row all fueses are good no security light on dash fuel pump turns on everything works inside the car lights dash stereo windows brake lights battery marks 13 volts all the the car does is click when turn the ignition
Maybe check your main fuses and starter solenoid, also if you have a friend try to measure the voltage at the starter, when your turn the key, it should be around 12v. Also trace your starter wires, make sure the ground is not corroded or broken. Also make sure the engine is not "locked" up(worst case scenario). Does your fuel pump prime when your turn the key. It's possible your battery is just weak, I would bring it to an auto store and have a load test done just to make sure. Voltage should read 12.8 when the car is turned off. When a battery is weak it might have enough power to run all your accessories but just click when you try to crank it over.
Where is the click ???
Under the hood ??
Is the starter clicking . Or the starter relay??
Check the small purple wire at the starter with a test light. ..
Test light should light when ign is turned to crank .....
I know you say no,security light
But broken lock cylinder wires are common ?
Do you have a way to check it for theft codes?
Under the hood ??
