Sponsored by: CARiD
Drivers side window not working correctly
Old Mar 8, 2015 | 03:36 PM
3Whips's Avatar
Default Drivers side window not working correctly
It will roll down like an inch at a time then you have to wait another like 2 mins or move the window around a bit and then if you roll it down it will go down a little more and you have to repeat the process... My passengers side is also very slow but actually works...
Anyways just wondering is this the window motor going bad? Or is it the window being off track? And are they fairly easy to install a new motor, or put the window back on track?
Old Mar 8, 2015 | 09:46 PM
McGinnis's Avatar
Most likely a bad or failing window motor. When they are about shot they cut out and then work after a few minutes. There is a heat resister in motor, that cuts out when it gets to warm to stop from burning out the motor. After a little bit it cools down and will work for a few more seconds. I would replace the motor, which is a pain, and involves drilling 3 rivets out and 3 small holes inside your inner door panel, while you have the interior panel off the door, use silicone lube on the window tracks so it'll glide better. Theres videos all over youtube about doing it. The motors run $25-60 depending on brand and quality. Also check if your window has some in and out play, indicating worn out roller wheels, or the window slides that are covered in a velvet material(one in front and back on top) can wear thin making the window loose.
Old Mar 9, 2015 | 05:40 PM
Cpt.Derrek's Avatar
Make sure to pickup a Dorman replacement motor vs the GM. The Dorman replacement has been redesigned to not fail like the OEM will.
Old Mar 11, 2015 | 09:35 PM
3Whips's Avatar
Originally Posted by McGinnis
Most likely a bad or failing window motor. When they are about shot they cut out and then work after a few minutes. There is a heat resister in motor, that cuts out when it gets to warm to stop from burning out the motor. After a little bit it cools down and will work for a few more seconds. I would replace the motor, which is a pain, and involves drilling 3 rivets out and 3 small holes inside your inner door panel, while you have the interior panel off the door, use silicone lube on the window tracks so it'll glide better. Theres videos all over youtube about doing it. The motors run $25-60 depending on brand and quality. Also check if your window has some in and out play, indicating worn out roller wheels, or a the window slides that are covered in a velvet material(one in front and back on top) can wear thin making the window loose.
Thank you both for the info, seems like a pain and I get cheap labor so I minds well let them do it. I'm guessing with part and labor I'll be around 100 bucks. Thanks again guys.
