2001 firebird formula rattling noise
Hopefully this is in right forum.....
So. I have a noise i can only describe as the wheel not being torqued down properly or the axle bouncing coming from my passenger rear side. Originally i assumed it was a wheel bearing, but after replacing both sides, i had no luck. Then i noticed the shock was basically shot so i also replaced both in the rear and still and no luck. The wheel is properly torqued, bearings are properly placed, brakes are perfect... Where do i go from there?
Thanks for any advice!
