Fog lights dont light up
okay i know there are multiple threads on this but none seem to have the particular issue i'm having... When i turn my fog light switch on, the switch light will come on with no fog lights in the car. When i plug the fog bulb or bulbs in then fog light switch looses its light and the fog lights don't illuminate. What do you guys think, ground? I know the relay works and i know the bulbs work and the switch seems to work with out the bulbs in.
Assuming you haven't figured this out yet...
When you install the bulbs, check and see what available voltage is at immediately before the fog light and immediately after.
If you have figured it out...
Nice job. If you feel up to it, reply to this post about what the problem was, just so others in your position down the road can read this and maybe help them solve their wiring issue.
The following users liked this post:
98SSHARDTOP (05-22-2021)
Did you ever figure out why foglights weren't coming on?
