Aluminum Window Motor Braces & Window motor retrofit questions.
There was a thread here awhile back where some guy showed how he had a piece of aluminum cut to fit the inside of his door and attached it to his door as a fix for the issue with the window motor replacement where the motor / regulator would start eating the fiberglass causing the window to sag or misalign. He had a pdf or something attached showing the exact dimensions of how to cut this aluminum sheet.
My passenger side window motor died and I'm also about to do some serious interior restoration so I figured I needed to address this as well. I couldn't find the dimensions of that aluminum brace but could anyone assist me in locating it and also how exactly they attached it to the door?
Thank you.
I know several of you have tried replacement aftermarket motors that were designed to be compatible with the OEM setup and regulator. I am also aware that for awhile Dorman had a good motor that has seemed to have disapeared off the market and no one knows where the design disapeared to. I am half tempted to contact Dorman to find out who exactly manufactured them and see if there's any way to get in touch with the manufacture.
Meanwhile however.. Our window motor designs were decades old even when our cars hit the show room let alone can they compete with anything on the market today. Costs and money asside.. is there any way regardless of how much re-wiring or modification is necessary, that we can retrofit a modern window motor into our cars? Maybe something like in the C5's and C6's or even 5th Gen Camaro's? I just can't understand why something like this wouldn't be possible and why noone has seemingly tried given the exponentially greater reliability and speed these different designs offer.. and by design I am aware of the possibility that it may not even be the window motor / regulator as the weak link, its just I don't wish to replace or swap these things every 3 years.
Thank you.
Save the manuals!
Once one does the shbox method for motor replacement, the problem with the regulator eating into the door is solved and the motor change-out becomes a 5-10 minute process. If one gets a lifetime warranty motor, the costs are extremely low.
That being said, I do have the "old" new design Dorman motor and I haven't touched them in almost 8 years now. (Dorman didn't design or make it - they just carried it as a part for a while. Autozone was the first to carry the part as a Duralast piece.)
Camaro,
Aluminum Window Motor Braces.
I know I've seen a PDF template someone made, but I can't find it. If you have no issues with the window glass stopping before the top, I'd say your regulator rivet holes are probably ok.
I'm VERY close on finishing up my own adapter plate to fit a better GM window motor for 4th gen F-body line. I have been researching and testing for over the past year and a half. I set out to do this project for myself, but I know how beneficial and helpful it would be for everyone else that knows how bad the original window motors are. I can't even count how many window motors I replaced in my personal 4th gens and 4th gens, STILL under warranty when I was a Mechanic at a Chevy and Pontiac dealer
My test so far show the crappy original motor takes 5-6 seconds up and 5-6 seconds down. My new better motor with adapter plate approx. 3 seconds up and 3 seconds down.
I'm still waiting on another manufacture's motor to test before I determine this project to be 100% complete. A Beta test on my personal vehicle shows a slight issue that might be taken care of by using a different manufacture motor. Right now the better motor with the adapter bracket is a direct bolt on without modifications, and I'm hoping to keep it that way
Need4Camaro- If you can wait a few weeks to tackle your window issue, I will be done with this project.
wssix99- From what it sounds like, I need to pay for a vendors spot here on LS1tech to post any links for selling these plates?
I've been reading so many posts about- "is there any better window motors for our cars?" and I've wanted to post so bad, but I wasn't ready. I finally gave in, but bear with me.
--Kyle
--Kyle
Camaro,
--Kyle
--Kyle
The regulator is not changed in any way. New better motor mounts to the adapter plate, and the adapter plate mounts to the original spot where the original crappy motor was. Basically a motor swap
Save the manuals!
Use Sil-Glyde grease on the rails and it will run good-as-new!
