Oil pan removal with transmission out
So im new to posting on here but i have read a lot of threads basically i was wanting to know if its possible to remove the oil pan on my 2000 ss with the transmission out or will i still have to drop the k member
Actually it's pretty easy to do if you raise the engine and lower the K-member. You'll have all kinds of room. That's when it makes sense to change the motor mounts. It also makes the mounts a breeze. Oh ... and while you're at it, if you have high mileage probably a good idea to change the oil pump and timing chain. You're already there.
