2000 Camaro V6 misfire? Help!
So i was driving my 00 camaro today, and i wound out 1st gear, it made a weird pop noise when i let off. Then later, in both 1st and 2nd, at or near WOT above 3500rpm, it started to rapidly misfire, kinda almost sounded like i was on the 2 step. Whats going on here?
You are aware this is an LS V8 forum, right?? If you get any response on this it will be because someone HAPPENS to know V6 characteristics.
No, no SES, i even plugged my scanner in to double check. I did alot of research and saw it could be anything from a dirty sensor to an intake gasket problem, so i figured id try checking the MAF and MAP, they seemed clean, so i disconnected the battery for a few minutes (didnt think it would do anything, but hey its free!) then drove it around through a heating cycle. I then starting to lay into it a few times, and everything seemed fine... problem solved? Technology is so goofy man...
