Radiatoe upgrade anyone done it ?
It's very hot around here , 90+ a lot of the time and the car is my daily driver with over 115k miles , it get hotter sometimes when in stop and go traffic , around 210, of course im gonna make sure everything else works in the cooling system, make sure there are no leaks anywhere and that the water pump works.
It a got a 180 thermostat already,
So what's everyone used that's upgraded, aluminum or lt1 style ?
Thank you
Patrick
Thank you
Patrick
There's nothing you can really do to enhance a properly running factory set up. Maybe put in an LT1 radiator like I did, but at these crazy hot outside air temps....it really won't do much.
Only option is to upgrade to a much bigger Griffin or BeCool radiator.......and better fans. And you MUST make a sheet metal shroud. The shroud is a very important part of the system.....which is overlooked a lot.
I'm actually looking now and researching which metal radiator to buy......but I'm also going big single turbo soon.
